when i get on it sometimes my truck will feel like its rocking back and forth, usually at like 50+ mph or so. it doesnt do it everytime though. usually its not getting traction until i get well into second gear.
my dads truck did that and we found the u-bolts that hold the rearend to the springs were loose. we got everything lined back up and tighened and the problem went away.. on another truck one of the bushings for the leaf spring where it mounts was worn out and gone which caused the same issue... i dont think it has anytihng really to do with the guts but i cold be wrong all your new found power could be killing the rearend...lol time to get the dana's in...![]()
I am gonna be a new Daddy...
Drive it like you live hard and fast....
'91 rcsb, 4.3 V6, 700R4 trans swap, 4/6 drop rolling on 18's, roll pan, 2" cowl hood, electric fan, TBI injector spacer, K&N filter replacement, flowmaster muffler...
[Today 08:09 AM] ChevyLee: dale would make a awesome dad in law too
i will check all that stuff and see if i can find anything.
i cant tell if the leaf spring bushings are worn but everything else seems ok. it feels like the power is being transfered from one rear wheel then to the other.
freaking truck is scary when you nail it though.
does your truck have an open rear or the g-80 unit?
When you do a burnout,does one wheel spin or both...if only one spins ,the truck is transferring weight from side to side and gettin squirrly..my wifes truck does that
you plan on putting in dana 60's right? that will solve your issues when you put those in.
