6.0 iron block, heavy rods, all new bearings, Speed Pro rings, balanced rotating assembly. It is assembled.
$1000 firm. p/u only
SOLD!!!!!!!!!!!!!!!!
will my heads fit on that block?
12 Sec. Club! SOLD
SOLD***
billy said it was all stock internals..
If it was forged internals, it would be significantly more.
The rods are LQ9 (raised bump on the beam), Speed Pro rings. stock pistons.
An easy 400rwhp combo is 6.0 block, 241 LS1 heads, decent size cam, and exhaust.
THANXS!
I will ask around if anyone needs a 6.0L
12 Sec. Club! SOLD
SOLD***
what heads do you have?
706
compression may by a little on the high side. Thats why I am using 241s on my 6.0.
