Results 1 to 6 of 6
Thread: Awd Dyno Md Or Pa?
    Oct 2007
    Baltimore,Md
    Awd Dyno Md Or Pa?
    I need help finding a place to get my truck on the dyno. I have been to AMS, Agile auto m, Extreme motor sports and to turbo xs , my truck is either to long or has to many lugs for there dyno pak. I have an 04 silverado ss. Does anyone know any place within like 40-60 miles to baltimore city that has one or has been to one there, thanks for your help.
    2004 silverado SS ,STS Turbo Gt-67 , TRT FMIC , Meth kit , 42lb injectors, patriot valve springs,Transgo shift kit, servos, built tranny ,e-fans and harness, e boost controller,3000 PI vigalante stall street tuned by F-body central Bret shook. needs to get on a dyno or track soon...
    Bloomingdale Illinois
    I know that Finish Line Performance here in Chicago is installing one as we speak. I believe that it is a dynojet model.
    Oct 2007
    Baltimore,Md
    What model ? alot of the dynojet and mustangs around here only go to a 130" wheel base , i need almost 150" .....
    Nov 2006
    Mesquite, TX
    Rick you can pull your front drive shaft to get your truck dyno'd...i was just reading about this on SilveradoSS.com and there have been a bunch of people do this
    Oct 2007
    Baltimore,Md
    I have been reading that 2 but the say something about hitting the brakes will mess up so alignment or something won't that give me slightly higher hp numbers aswell i think i may have found a shop they said the think they did a ss silverado before it is ultimate performance in dulles,va, which is like 50 miles from me other then that i would have to buy a set of 6 to 5 lug adaptors to run on a dynopak at agileautoperformance.com
    Jun 2007
    pm QUIK on here i believe hes near ya somewere!
