Results 1 to 10 of 14
Thread: injector size ?
    Jun 2007
    injector size ?
    i just ordered some 72 lb injectors ,my ? is do i need a tune waiting from my 42s or will it run till i get the tune for the 72?thanks
    Jun 2007
    buuuuuump
    Oct 2005
    drinking your alcohol
    my guess is a new tune is needed.....
    i know when i was talking about upgrading mine i had to have a retune
    DamnYankee: my nana failed
    Jun 2007
    thanks ,anymore opinions
    Apr 2005
    Need a tune.
    Gone, but not forgotten!
    casey23 Guest
    of course you need a tune... What are the details on the 72s that you bought? are they motron 60s that are rated for 72 lb/hr @ 58psi??....
    Jun 2007
    all i know is the book said they were 72 lb accells and they were universal fit .idk what uni fit is supposed to mean but im praying theyre right .and i do know ill need a retune but i was wondering if they would be ok for a week or so wile i get my rails reg and lines repositioned?
    casey23 Guest
    Sorry dude.. Not going to happen.. Its almost double the size i dont see anyway that they will work... did you need an injector driver to go with them??...
    Jun 2007
    Quote Originally Posted by casey23 View Post
    casey whats not going too work? me not waiting for the tune or the fn injectors at all ? even with my application.i have an aeromotive f/p setup if that matters.idk.SEEE YOOU SHOULD OF JUST SOLD ME YOURS AND I WOULDNT BE GOING THROUGH THIS ID KNOW THEY WOULD WORK.
    Jun 2007
    it doesnt say of course that i need an inj. driver.whats up.
