Results 1 to 6 of 6
Thread: headers
    headers
    purchasing a set of pacesetter headers tonight off of ebay but wasnt too sure on to go with long tubes or shortys. Is there a real big difference in the hp gains?
    Mar 2006
    Mesquite
    Shorties don't flow much better than the stock manifolds. The stock ones actually flow pretty good. So if you're going to do the swap, get some long tubes.
    Oct 2007
    Bandera, TX
    I agree, LTs.
    single digit street truck
    for build info
    go long tubes bro
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
    S.A. Texas
    pacesetter lt's are the way to go, love mine
    Jun 2007
    long tube pacesetters,they were 1 of the best mods i did .
