Results 1 to 10 of 18
Thread: po758 whats up!
    Jun 2007
    po758 whats up!
    ok so this morning i take my ground off to reset after changing maf.here we go so i start up run fine and what do ya know i wont come out of secand gear.and im kicking po758 omg what else is going on here im sureit has to do with taking ground off or something tranny shifted fine when i parked it .help me out here guys .im so sick of this game.
    Jun 2007
    o i forgot i did take ground back off and reinstalled 5 times .
    Aug 2005
    St. Anthony, Indiana
    Jun 2007
    ok i i dont believe its the 23 selinoid cause i parke it last night.so what grounds do i chase down?its coincidental that i pulled the ground off and part of that code has t o doowith grounds.
    Jun 2007
    ok so is there a wire that goes from pcm to trans i can loook for or a specific ground wire ,i mean what the heck hor rediculous.
    Jun 2007
    the codes dont really spell it out .maybe i should post in electrical dept?cmon i know theres some elec gurus out there!
    Jun 2007
    WOW ,nothing i cant believe it must be noone knows about this stuff.im sitting here hanging out dododododo.wondering what to do next .
    Sep 2006
    Coon Rapids, MN
    B.f.h.
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    Jun 2007
    Quote Originally Posted by 02CHEV View Post
    B.f.h.
    whata this bfg?
    Sep 2006
    Coon Rapids, MN
    No NO I said a Big.F***in.Hammer. cause I am stumped
    04 Grand Prix GTP
