Originally posted by mustbbrent+Feb 28 2004, 04:38 PM--><div class='quotetop'>QUOTE(mustbbrent @ Feb 28 2004, 04:38 PM)</div>
<!--QuoteBegin-SportSide 5.3
@Feb 28 2004, 01:53 PM
you need a good cam for your SS. that'll extend your rpm range out, and keep the hp climbing.
then those punks wont catch up to you no more
I read about Black60HD and his huge CAM. I just need to find out if it lost torque in the 2k RPM range.
Today was the first day for the truck to pull a boat and trailer. It did well except for the lowered rear end. It sure looked like it was close to the bottom. [/b]
I think you will be happy with a cam like mine, it really made the 6.0 come alive and it will still tow good. Even without the stall it would pull hard on the bottom end. It comes on hard around 2600-2800 and pulls hard up to 6500. I would shift it higher in first, but i still have stock rod bolts. I think the best part with the cam, is the sound at idle.
01 4WD 6.0HD- NELSON custom tune/ 224/224-578/578 112lsa synergy motorsports cam / asm's, 3'' to x-pipe, to y-pipe, 4'' top ten flowmaster / smi 9 1/2'' 3500 stall/ smi 4l80e/ intake/ ported t-body (nitrous system) cheater solenoids, 2 fogger nozzles , holley blue pump, regulator and 1 gallon cell
