After planning everything out to go through with a rebuild of the 6.5 diesel in my 1993 1 ton crew cab 4x4 I couldn't get over feeling uneasy about putting over 5G into a fundamentally flawed engine that's not exciting in the power department. I've decided to change over to a gas engine. The mileage won't be there but the fun factor will! I think for less money I can put in a new complete carbed 330 HP 350 from GM if I do the install. I know this engine would bring a smile where the diesel would just have me worried about another failure.
I'm trying to think what obstacles I'll encounter. Here's what comes to my mind. I'd sure appreciate any help.
1)Thoughts about this choice of engine? (I don't tow much now but who knows about later). Think I'm crazy? Guys on the die hard diesel forums do.
2) Accessories. Don't know if I can just get 350 brackets and use my existing AC, alternator, power steering?
3) Motor mounts. Plan to get new - should bolt in. Get these from GM?
4) Exhaust. Manifolds from wrecker? Could do headers - I hear they can be a nuisance, worth the cost? What brand?
5) Radiator/Shroud. Plan to get fan from wrecker. Don't know if fan on 350 will line up? Maybe just change shroud?
6) Clutch. Has 5 sp (like it). Will need flywheel, likely clutch parts too? Clutch was recently replaced but I'm guessing it's incompatible.
7) Gauges. Plan to get gasser guages from wrecker (tach is different).
8) Fuel Pump. Put mechanical pump on 350 and toss diesel lift pump?
9) Fuel. Drain diesel and flush lines!
10) Starter. Just get 350 starter and hook up?
11) Dual battery system - keep it?
12) Throttle, cruise control. Get from wrecker?
I know I'm missing things. Any bit of advice welcomed.
Thanks
Arlie
