ok the guy at sdpc told me that they sent back all thier 918's and i told him the cam i bought and he said the yellow zo6 springs would be fine. its a comp extreme 269 with 216/220 .525 .532. i want to rev too 6500 with these springs be okay?
2008 Trailblazer SS LS2, K&N CAI, flowmaster 40 series, hp tuned
2004 Trailblazer 4.2, K&N CAI, hp tuned
2002 Camaro Z28 5.7 ls1, lid, slp loudmouth, bbk longtube headers, ory, hp tuned, tr224 cam, ported 243 heads, moser 12 bolt w/ 3.73's and full spool, and a 100 shot just in case. 463whp, 458 wtq 11.32@ 120 1.52 60' on motor no spray times yet
they'll be fine. i used the same spring to rev my 5.3 with a 216/224 .551 to 6400 and i also use a set to rev my new 5.3 with a 212/218 .522/.529 to 6400...and i'll prolly use a set to rev my turbo'd 5.3 to 6200...
midweststreetcars.com
the yellow zo6 springs are good for .570" max lift right?
Yup. They will be fine. Just make sure to give the motor proper warm up time before rapping it up past 3K RPMS. Those springs are a little more brittle than 918s... You might get some extra valve train clatter, but hopefully your exhaust will drown that out![]()
well the guy at sdpc said the 918's have been crap lately and they sent every set they had back. so if the zo6 yellows will be fine and they are over 100 dollars cheaper, then great!
Just happen to see where they (Comp) are replacing the 918 with 928 , something about a free swap out if you have the 918 .
Now what is a tune again?
Comp Cam 54-412-11 , Int:265, 212, .522 , Exh: 271, 218, .529 , LSA 114 , Longtube , CAI (Vararam) , TransGo HD2 shift kit , tuned by me with EFILive
