Results 1 to 10 of 12
Thread: building my heads.
    Jul 2007
    eastern shore of virginia
    building my heads.
    i am new to engine building. i just got my ls1 heads and want to know what springs to get. im on a budget. sdpc has some good springs, but i dont know what to get. i want to raise my rev limiter to take advantage of my cam so i need springs that will allow that. the cam is a 216/220 525 532. so its not too much lift or duration. nothing crazy. will the sdpc pro beehive ls1 valve springs do alright. i dont know what the 318 lb open 130 lb on the seat means
    2008 Trailblazer SS LS2, K&N CAI, flowmaster 40 series, hp tuned
    2004 Trailblazer 4.2, K&N CAI, hp tuned
    2002 Camaro Z28 5.7 ls1, lid, slp loudmouth, bbk longtube headers, ory, hp tuned, tr224 cam, ported 243 heads, moser 12 bolt w/ 3.73's and full spool, and a 100 shot just in case. 463whp, 458 wtq 11.32@ 120 1.52 60' on motor no spray times yet
    Jul 2007
    or will the ls6 valve spring set be alright they are way cheaper
    Quote Originally Posted by the_jester View Post
    318lbs valve open pressure and 130lbs valve closed pressure on the seat!
    Jun 2007
    just wanted too say thats a descent pulling little cam ,i had one in a truck and it pulled hard right up too 6500 rpm.
    Jul 2007
    will it perform well in a supercharged 5.3
    Oct 2007
    i guess the longer exhaust duration would help build cylinder pressure...
    02 Sierra... motorless for now.
    02 SS.. stock bottom 4.8, 241's, 224-220/116+4, 918's and pushrods, front mount turbonetics 78mm, HKS GTII, TiAL, eBoost2, Yank PT3600, Performabuilt 60e, solid motor mounts. Tuned by me with HP Pro and LM2/AFX
    levelland TX
    springs
    you should check out the prc dual springs they will last forever they can handle 660 lift so theyll take a beatin, or maybe the compcams beehive springs they are really good springs also.
    Jul 2007
    i went with the yellow ls2 springs
    Good choice. They will work great! Any updates on the build progress?
    Jul 2007
    yeah, the cam is in, the studs are in, now im installing the springs and pushrods, then put the 853 heads on and start reassembling stuff.
