Results 1 to 9 of 9
Thread: im a little worried now.
    Jul 2007
    eastern shore of virginia
    ok i just bought this cam for the silvy. 228/232 .588 .595 110lsa. i heard a clip of it and it sounds amazing. nice choppy idle. but is it gonna be drivable. i do have a 2500 stall. and I'll get tuned for it immediately. its gonna go one with a set of ls1 66cc heads. this was a daily driver till about a month ago when it started going from one shop to the next. but i would like to get back to driving it. i dont care if i cant tow with it anymore.
    2008 Trailblazer SS LS2, K&N CAI, flowmaster 40 series, hp tuned
    2004 Trailblazer 4.2, K&N CAI, hp tuned
    2002 Camaro Z28 5.7 ls1, lid, slp loudmouth, bbk longtube headers, ory, hp tuned, tr224 cam, ported 243 heads, moser 12 bolt w/ 3.73's and full spool, and a 100 shot just in case. 463whp, 458 wtq 11.32@ 120 1.52 60' on motor no spray times yet
    Dec 2003
    Newark, Tx.
    the clip is in my truck. It was a stock 5.3. You may think about a bigger stall though. It will drive fine with a good tune.
    That is a pretty healthy cam for the 5.3L. The numbers look good for a FI cam except for the LSA. From wat I know, you shouldn't go lower than a 112 at the most for FI. Your TC will help out some, but it might be a little thin down low. Just make sure your CR doesn't get too high with those new heads... You may be getting close to 10.2:1 CR or higher. Sure, that isn't that much higher than the stock numbers, but you don't need to be raising the CR with FI and the new cam you got. Billy is correct, with a good live tune, it should run pretty well...
    Apr 2005
    Same cam I have, but in my 408.
    Drives fine when it runs.
    Gone, but not forgotten!
    Dec 2003
    Newark, Tx.
    If he is FI, then it is not a good cam for it.
    Jul 2007
    with the larger combustion chamber i will be lowering my compression, right? the ls1's are 66cc and the 5.3 are 61cc.
    damn it i knew it. i was thinking that that much overlap might not be good. sh!t
    Jul 2007
    well how not good? will it hurt performance? should i just try to sell it and find another cam?
    thats the same size cam maxim at comp sugguested for my set up, i thought it was rather big, but didnt know, so i called comp back the next day and talked to jeff i think, he took sometime to spec the cam out he ended up giving me 2 sizes but more realistic it seemed like, sizes were 224/224 or 222/224... 2 different people 2 different cam specs per ideas ... hmmmm !!!!
    Quote Originally Posted by skeet View Post
    oh yeah this was in a 5.3
