Thanks guys! Well as for the 2500 I do have some plans just not 100% sure what yet.. I need it to do a couple key things that i'm sure will throw off any big big power plans.
I have a 20ft gooseneck the s10, jeep or atvs rides on.. empty weighing in at 3700 lbs and loaded were looking at somewhere between 7700 lbs and 9,000 lbs but usually around that 7500-8000lbs. I haven't towed it yet and don't even had a hitch in it but my main tow rig is a 1995 6.5L CC LB that just flat gets it.. loaded truck 5 people 10,000lbs towing holding 75-80mph up hills getting 13-14mpg. But i still want the 03 to be able to do it.
Second the truck is my DD.. i've already got two garage queens (s10 and a Jeep). Best i've EVER done for gas milage was 17.3 mpg and that was 95% highway...I would like to see 17-20 (i know i know..)
2003 Silverado 2500 6.0L/New 4L80E HD2 Kit, Bilsteins, Reg Cab LB 2WD.
1994 S10 - McCoy/Hitech Built forged/cryo 4 bolt ty bottom end, CAMS,inc vortec heads full rollers etc, PT60 Turbo, bar & plate A2A, meth inj, Custom MPFI intake and plenum #65 lowz inj, LSX TB, MS2 PCB 3.0 EFI, 4.3L 43K,8.5 posi & disc 3.42, C5 vette brakes
1994 Jeep Yj, fresh frame off build, 4.0L banks header, B&M short throw, BDS & BILSTEIN susp., waggy D44's w/flat top knuckles, PM's crossover, 1ton hydroboost, PSC powersteering pump, GM 2500 front disc setup, GM front 1500 Disc on rear, 4.56's & ARB's, 35 MTR's
