Results 1 to 10 of 23
Thread: Coolant question
    Coolant question
    Ok, all of a sudden my truck just shoots out all of its coolant. Its a 1998 Chevy 4.3L
    here is a pic of what the res looks like for the coolant.
    ok so i fill it to the line then in about a week its all gone. it just squirts onto my frame.... the truck is not over heating at all either. but it just is squirting out every time it runs and it squirts out a lot.
    any idea's what the problem is ? and why is that tube just pointed at my frame
    btw thats not a pic of my truck i just used one from ebay. :p
    Pressure test it and find the leak..
    Mar 2004
    NY
    Maybe intake gaskets. Very common on 4.3. Could be building pressure and the overflow is the weakest point.
    2015 GMC Sierra RCSB Z71 5.3
    hm, that stinks to bad i am putting a 6.0 in next month or i would fix it
    thanks guys
    ff_jeff Guest
    I agree
    Quote Originally Posted by FLATOP08 View Post
    My wife drives a 97 4.3 and I just replaced the intake manifold gasket. 85k miles. no coolant squirting out of the overflow though. check your oil. see if it appears milky, mine was fine one day then the next it looked like it had way too much oil. turned out it was coolant. if it is, i bet it is, itll cost about $400 for a mechanic to change the gasket,tstat, and oil. dont run it with coolant in the oil, youll float the bearings out of the bottom end. and dont use the magic bottle of stop leak either. Also: open the oil fill cap after running and steam should be present if leaking into oil.
    SORRY SO LONG.
    Quote Originally Posted by vff_jeff View Post
    SORRY SO LONG.
    thanks ill take a look
    only has 53k miles on it an i had that gasket and a few others replaced about a yr ago.
    Dec 2003
    Azle,TX
    Its a 4.3...maybe it gets excited and starts squirting...like my dog! LOL
    Vortec Performance Tuned
    Quote Originally Posted by COWL327 View Post
    Thats funny right there I don't care who you are.
    I like cats but only certain cats. The ones that are bigger and meaner than most dogs.
    If you are scrapping the 4.3 for a 6.0 soon, just leave it alone... Just drive it and monitor your coolant levels and engine temps...
    thats what im planing on doing. thanks tyler
    haha! my stupid cats pee on everything of mine even my truck it makes me so mad
