I am gettin ready to install my walbro 255 FP. How do I get it to fit in the factory bucketI'm confused. It's smaller than oe pump.
I am probly making this harder than it needs to be.![]()
04 Grand Prix GTP
03 Z71 wanting a Turbo ,Stall, and Tune BAD
THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
ya its smaller ,drill 2 holes in the side of the bucket and use a zip tie too hold in place.
Any pics on how this is done?
04 Grand Prix GTP
Call Billy (817-703-3750) or Allen - one of them should be able to help you as well...
If I remember right, mine came with a foam sleeve that it slid into, then I put all of that into the bucket.
is that the thing that goes on the bottom of the pump?
04 Grand Prix GTP
No mine fit around the entire body of the pump and all the way length wise of the body.
