Results 1 to 4 of 4
Thread: Ordered new pulley
    Ordered new pulley
    Ordered new pulley from whipple 3.75 should be 10psi or more. Small as my charger would take. Hope I don't blow it up.
    Any guesses how my 1/8th improves. Currently 9.5 in 8th.
    Also gonna order AEM UEGO and install air temp sensor after the charger. Not to mention pin the pulley.
    casey23 Guest
    HELL YEAH !... You will thank us Later on ....You truck has everything it takes to run 10psi ... good tune and take advantage of that meth i hope you pick up .8 in the 1/8 put you in the 8s for sure You will wish you did this long ago U might need a bigger Meth Nozzle....
    Yeah--pin that biatch! That is crucial id running 10 psi. But like Casy said, you do have the right components to run 10 psi--just make sure you up the ante a little with the meth...
    thanks guys
