I have a 1982 Chevy Silverado with a 6.O from a newer truck. The motor has a Comp Cams (226) camshaft, hardened pushrods, and 918 springs. It also has Katech rod bolts. Induction is a open element air filter/Holley 750DP, and a victor jr. Ignition includes stock truck coils operated by an MSD 6010 Ignition Controller. Exhaust is a set of Pacesetter longtube headers into 3 inch true duals and then flowmaster 10 series mufflers. Cooling is handled by dual Flex-a-lite fans and a HD radiator. Fueling is from a Mallory Comp 110 electric pump and 3-port regulator - all fed from a 16 gallon fuel cell(using some braided lines and some aluminum hardline). Transmission is a TH350 that needs to be rebuilt and also doesn't include a converter(but comes with a 40,000GVW cooler). Rearend is a 8.5, 10bolt with a GOV-Lock posi and 4.56 gears. The body is in OK shape and is painted black(50 footer). Headlights work, but I'm not sure about the rest of the lights. The wheels and tires are just junkyard parts that need to be replaced. The interior is stripped down - only bench seat(excellent condition) and a Hurst ratchet shifter. It does have a cd player, but you probably won't hear it over the exhaust. It has all autometer gauges and a shiftlight.
If I get my asking price, I will have the trans rebuilt and throw in a 3500rpm converter. At this point the truck is not completed(only needs minor wiring to turn on). Let me know if you're interested, we can negotiate on the price. I'm asking $6500.
