Results 1 to 7 of 7
Thread: Crazy Fuel Gauge
    Mar 2004
    Springfield
    Crazy Fuel Gauge
    Reads empty when the tank is full, reads half a tank when there is only a quarter, dances around when in the park position and radio is on.
    At other times it works just fine, but the problem is progessing. So I dunno if you guys have had this problem but I'm just trying to find a direction to go in.
    I've been told its the fuel regulation, poor fuel pressure, fuel pump is going out, dirty sensor and my whole speedometer needs to be replaced.
    I just want to hear from somebody that knows what they are talking about, not just throwing something out there.
    FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
    CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
    OR TO GET ME PERSONALLY CALL: 1-615-943-6514
    2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
    Dude, mine does that all of the time too. So far I don't have any issues with fuel pressure or leaks. But since I know the GM trucks' factory fuel pumps, I know that I will have to replace it soon...
    San Marcos Texas
    I think most of the time it is the sending unit. I have heard of a few gauges needing replacing so I guess it will need some looking at to get it right.
    Dec 2005
    Deer Creek, IL
    Mine does it too. My Chevy dealership says it's pretty common, and more of a neusance than anything. I usually just go by the trip.
    New project truck:
    '00 ECSB 4wd, 5.3, 3" body lift, gap guards, 18x9 Moto Metal 951's, 305/60/18 Mickey Thompson MTZ's
    To-do list: Built rear end, 6.0 swap with built top end, 4L80e, and a couple bottles in the bed.
    Irving, Texas
    mines doing that right now except its almost like the gauge reads opposite. i heard that all you have to do is change a few settings in hptuners so once i find out what to change, ima try it. if that dont work, i guess ill take it to the stealership.
    2004 Avalanche 5.3L
    Show: 2/4 drop, 22inch Gitano rims, kuhmo rubber, custom sound, grill guard
    Go: Custom true duals, hpt olsd, transgo hd2 shift kit, vette servos, efans, underdrive pulley, tsp 224r with 112 lsa, 3200 stall tq, sway bars, shaner tb, throttle body bypass
    2003 7.3L Ford Powerstroke Diesel
    Mild 100hp tune, straight pipe, k&n airfilter, small 3 inch lift with 35's, larger turbo, LOTS of soot
    Mar 2006
    Houston
    its a fuel sending unit...it did the same thing on mine and my sister truck had to replace it then worked perfectly fine...btw i think i paid around 380 for mine
    2001 seirra 5.3L ex cab.-- 93 performance Nelson Tune,longtube pacesetter headers, ory, magnaflow with electric cut out, airaid cai, throttle body spacer, clear corners, 1400 watt system, 2 ifinity tens custom boxes, panasonic head unit, punch grill....sold :-(
    09 camry se v6....gotta have a gas saver while in college...still gets up and goes tho
    wiggle the harness before you spend the dough!
    Do the "wiggle" test on the tank harness, while watching for a change.
    Check the wire connectors, remove the retainig device, release the pins from the plug, and check for corrossion. I have been finding al sorts of OEM plug connectors that are corroded and really screwing up my ride.
    The sending unit could be bad, worn down, most likely dirty of fuel varnish on the fingers, TRY "Seafoam" I would bet on wireing, only cuz i had one and in my hand all day. And them damn connectors have been giving me fits.
    More details if you want:
    I have a swaped 04 5.3/4l60e into a 88 k5 with a 04 cluster, Well aftera few years I just got around to finishing the sending unit today, I didnt take any pics though, sorry. I was chaseing a fulke huch about my fuel pump any way.
    The actuall sending unit and float part is held onto the fixture that goes into the tank by a couple clips, You could change just that part of it from a bone yard unit. Some body makes that part brand new every day for DELPHI but i dont know who. There are two real delicate metal fingers that ride up and down on a serarted contact strip. The fingers are attached to the tank float. The strip has a wire that goes to ground and the fingers have a wire that gets 5 volts from the pcm. The resistance changes as the float goes up and down, the fingers are in differnt spots as the level changes.
    The pcm is detecting change in resistance, at the tank unit, thru the connections, thru any corrosion, accross bad wires could be any where the pcm dont know and dont care, just the change. The guage is reflecting the change the pcm is seeing, also could be The dash, fuel indicator is class 2 serial data, some thing is getting lost between the pcm and the fuel needle.
    Them Delphi/packard connectors are nice for a while, they are all sealed and any moisture that does happen to get in cant get out. They have alot of "tsb"s that have to do with these connectors, all over the truck/car. The plating used, the crimping methods used, the size of the seal used vs the insulation thickness of the wire.
    swap : 88 k5 Blazer w/ 2004 5.3 & 4l60e, 212/218 cam
    CAI, shortie headers, TCI 2600 stall, transgo shift kit,
    Nelson tuned
