Results 1 to 5 of 5
Thread: fuel pressure ?
    Jun 2007
    fuel pressure ?
    i just thought of something ,ive got an earomotive fuel pump setut externa,with regulator ,i was wondering if im supposed to take off the vaccum line too reg when adjusting fuel pressure ,if so i think i forgot to and it may be causing issues to me,o i forgot ,supurcharged with 42 lb inj.what do you think my pressure should be running and juust turn key.when i just turn key im at 54 lbs and running 58 after 3k i have a fmu that kicks it up too 60.any input apprecited.thanks
    Jun 2007
    bumpity bump me back up .id like too know/thank you
    54 sounds kinda high for idle, but then again, you've got the 42lb.ers with the Vortech... Your numbers sound 4-6 lbs too high, but most of that can and will be corrected once get the new tune. Your A/F ratios will be corrected for all that you have done this past weekend...
    Jun 2007
    What About When Checking I Am Supposed To Pull The Vaccum Off The Regulator Correct?i Might Not Of The Last Time ,hope It Didnt Make That Much Of A Diff When I Adjusted Up .input Please
    That is where I would put it if I was checking it...
