Results 1 to 9 of 9
Thread: very dissapointed
    Apr 2007
    friendswood
    very dissapointed
    i read something very dissapointing, someone correct me if im wrong. Procharger says that their system is not compatible with flex fuel vehicles. I really want the charger, but does that mean that no charger works with my system. I will have to sell my truck if i cant even upgrade it anymore. Someone help me out here, there has to be some type of FI for my truck. damn flex fuel
    2006 ecsb silverado, AFE Cai, Jet Maf, Pacesetter Ceramic Coated Lt's, true duals with Dynomax Bullets, cats and o2's....still emissions legal!
    "Ford...At least they circled the problem".
    San Marcos Texas
    I think what they are saying is you can't use e85 with the procharger. I know that Allen has installed FI on flexfuel trucks.
    Jan 2006
    If you are FI you can't run anything less than 91 octane or you will ping. The charger will work, but you can only run premium fuel in the beast.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Apr 2007
    friendswood
    ok then i feel like an ass now! It makes sense, ok well i guess i better start saving. Thanks guys, oh yeah do i need to do internal work before charging the beast?
    Jan 2006
    Quote Originally Posted by silverado06 View Post
    You can run a stock motor. The only thing that needs to be done is a retune. I would go with an inline fuel pump and maybe some heavier valve springs, but that should be the minimum. Also beef up the trans.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    San Marcos Texas
    Hey not a problem! I bet there are tons of guys not buying one one for the same reason. You could run one with e85 but once tuned for it you would be stuck running it all the time. e85 is 100-105 octane. The nice thing about flexfuel trucks is they already come with bigger injectors and fuel pump. They might still be a bit on the small side for more than 5 psi. I think they are 35lb injectors.
    Jul 2007
    eastern shore of virginia
    im running stock injectors in my slivy with 10 psi. procharger includes a fmu to up the fuel pressure.
    2008 Trailblazer SS LS2, K&N CAI, flowmaster 40 series, hp tuned
    2004 Trailblazer 4.2, K&N CAI, hp tuned
    2002 Camaro Z28 5.7 ls1, lid, slp loudmouth, bbk longtube headers, ory, hp tuned, tr224 cam, ported 243 heads, moser 12 bolt w/ 3.73's and full spool, and a 100 shot just in case. 463whp, 458 wtq 11.32@ 120 1.52 60' on motor no spray times yet
    Dec 2003
    Newark, Tx.
    you can do it. We have done turbos on flex fuel trucks.
    Get the 42lb injectors. No need for a bigger fuel pump--it's already got it... You can FI a stock-bottom end LM7 reliably to about 8-9 psi without any issues.
