Results 1 to 8 of 8
Thread: Anyone have the factory specs for cast number (852) heads?
    Jul 2007
    Colleyville, Tx
    anyone?
    61.15cc Chamber Volume
    9.5:1 compression on a stock 4.8 or 5.3
    200cc Intake Port Volume
    70cc Exhaust Port Volume
    1.89 Intake Valve Diameter
    1.55 Exhaust Valve Diameter
    Putting these on an LS1 engine yeilds 10.9:1 compression. Milling .030 off the bottoms will yeild 11.5:1 on the LS1 5.7L engine. Intake valve upgrades are recommended for performance applications.
    Jul 2007
    Colleyville, Tx
    Sweet thanks for the info man i wanted to compare them to the 706 heads and work my ideas from there....
    Casting Number 706
    Head: 1999+ LR4 4.8 Litre Truck
    1999+ LM4 /LM7 5.3 Litre Truck
    Material: Aluminimum
    Part Number:
    12559852
    12561706
    Combustion Chamber Volume: 61.15cc
    Compression Ratio: 9.5:1
    Intake Port Volume: 200cc
    Exhaust Port Volume: 70cc
    Intake Valve Diameter: 1.89 inches
    Exhaust Valve Diameter: 1.55 inches
    852 heads
    They both have the same specs??? thats weird... so whats the difference between each other??
    You had the data already. The 706/852 is just the last three numbers of the PN on the head.
    Jul 2007
    Colleyville, Tx
    lol, oh dang....I just now noticed that....
    Jul 2007
    Colleyville, Tx
    ok... i knew something wasnt right with what my brother was telling me i guess i got the info confused...
    the heads he pulled off are "243" heads.... but from what i've been told that those heads will actually hurt my truck... I thought that they would boost my compression and since they have a bigger intake valve they would be a better set head then my 852's
    Jan 2005
    Humble/Houston TX
    would you like to sell the 243's? if so PM me a price.
    old mod list: H/C/I/N/E/G 408
    Jul 2007
    Colleyville, Tx
    Sorry, I'm going to keep them... i'm still planning on using them just not on my 4.8L
