Results 1 to 8 of 8
Thread: can you switch an awd over to part time
    Sep 2006
    Coon Rapids, MN
    if you have an awd silverado SS can you switch out the trans and T-case and stuff from a Z71. to make it a part time 4wd just a thought. I have found a pewter SS that i like alot and trade my truck in for it
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    You could do it, but with all of the wiring and computer issues you'd run into, it wouldn't be worth it...
    Dude the AWD system is awesome. Awesome Awesome Awesome. I want to convert my truck from z71 to AWD. I drove a denali truck with it and let me tell you it is the shiznit. It does not matter the terrain or wet weather it is so much more stable. I would swap with ya if I knew how to change everything over. For me i think all i would need to do is get the right transfer case and unplug the electronics.
    Sep 2006
    Coon Rapids, MN
    I use to work at a shop and did alot I mean alot of work the awd t-cases. PITA!!!! the viscus would go bad all the time. I like having a choice of 4wd or 2wd.That just me though.
    04 Grand Prix GTP
    May 2006
    Waco TX
    Quote Originally Posted by 02CHEV View Post
    I've never seen an AWD pewter SS. Weren't the pewter ones 2006 models? and weren't those all 2wd?
    Sep 2006
    Coon Rapids, MN
    Quote Originally Posted by Red03SilSS View Post
    Dont know guess I didnt look at the window sticker that close
    04 Grand Prix GTP
    May 2006
    Waco TX
    Guess if you really wanted 2 couldnt you make a 2wd a 4wd? Haha. Than you would have the option of 2 or 4 in an SS.
    DBYRD Guest
