Anyone have any? I am gonna plug in some mods but would like to start with stock. Unfortunately it looks like the DD software doesn't have these engines and I don't know a lot of these stock specs.
I had to pick the SB 305 and then tweak the bore and stroke. No clue on the rest of this. Don't know any of the stock cam specs either; I would like to at least verify the stock numbers to make sure I am starting from the same point.
Thanks,
Andrew
http://home.nycap.rr.com/agreif/Truck/DD.jpg
Andrew
2001 Silverado 6.0 RCLB - Home Page - 4.8 to 6.0 Swap
Nelson Tune, Comp Cam XR265HR, Pacesetters, Hotchkis Sways, 3.42, Eaton Posi, Transgo, LS1 Fans, Magnaflow, Eagle 219's 18x9.5, Fold-a-cover
i have my heads/cam LS1 file in Dyno 2003. i use it to tinker with what cam to get with stage 2 heads.
Hugger Orange 99 SS Hardtop #756
485rwhp/440rwtq SAE
OK, I got the baseline to look ok, but it's using a generic cam and just a shot in the dark for flow.
Firts one is using a performance street cam and the second is using a economy cam. Street perf looks closer to stock numbers, with the numbers and RPM peaks being almost right on.
Andrew
- You may not post replies
- You may not edit your posts
