Remember, if the stall is smaller in diameter, then less fluid in the tranny. I am assuming its a 60E. A deeper pan and a larger trans cooler is a must for that size stall. He needs more fluid in the trans to keep it cooler. If his temps are that high he will fry the trans. if he doesn't watch the temp.
This may not be the case, just my 2 cents.
Jamest
12 Sec. Club! SOLD
SOLD***
