cooler question !
i have a air to water setup on my truck now ,i installed a e fan in front of cooler in grille ,i bought an awesome larger cooler today for an awesome price ,thinking i could piggy back them and get lower iats now im getting low 100s for iats ,would this be benificial to do or am i totally wrong ,been known to be wrong after many thousands of dollars ,lol.any opinions would be appreciated ,thanks .
Your concept has been thought of before, and I cannot remember whether you are making any headway by putting two fans on there or not... The thought of doing it makes sense--you would need for your electrical system to be upgraded; e.g. bigger alternator; besides that, I am sure that you can get significantly reduced IAT's by having that setup. Make sure that when you wire the fans--fan on the inside of the rad. to be the puller and for the fan inbetween the cooler and grille to be the pusher...
im trying too find out if piggybacking the coolers will help or not .not the fans ,the one that came with it is 6x12 and the other one i found is 12x 12 i thought id bounce one too the other and circulate through both if it was benificial to the iats or is it overkill idk?how low can or do you want youre iats ,?i mean at what point does it not help too go lower or is it better too just keep trying too get better iats ?thanks for opinions.
- You may not post replies
- You may not edit your posts
