Results 1 to 10 of 11
Thread: STS Oil Pump took a crap?
    Jan 2006
    Needless to say oil in the pipes again. This time I turned off the motor when the alarm sounded. Luckily I was 3 blocks from home so my dad pulled me home.
    Allen I need an oil pump,do they make a better pump, do I order that from you or STS? I know its the pump, b/c when the key is turned on the pump kicks, but no prime noise like it usually does.
    Oh well, at least I did a wax, oil change and plugs on it today.
    Now it will just have to sit until I get a pump.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    San Marcos Texas
    This is the one. 3GPM Gear Pump 12 or 24 Volt I don't know if STS sells them or this is the only place to get one. You might check for voltage and ground at the pump before you give up on your pump.
    Jan 2006
    Quote Originally Posted by GMCwantsLS1 View Post
    Thanks for the info. I will do a voltage check tomorrow. I can feel the pump want to turn, but it wont. I wonder if you can rebuild these. If good on the voltage, I will order the pump.
    Thanks,
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Jan 2006
    O.k. I ordered the pump, if I do not need it I will return it. Just need it fixed quick.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Are you gonna have to go through that long process of getting the oil out of everything like last time? Or is this just a quick fix... so to speak..
    Jan 2006
    I do not know. I will find out tonight. I turned off the motor quick this time, so I hope it only went out the rear. Will see.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Jan 2006
    Quote Originally Posted by Jamest View Post
    Jamest
    Pump will be here WED. It will take 30 mins to put on and I am back up running.
    Thanks, for the in GMCwants LS1!
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Apr 2005
    You almost needed that motor sooner than you thought!!
    Gone, but not forgotten!
    Jan 2006
    Quote Originally Posted by SCIV View Post
    HA HA! I thought it was toast at first when I saw the smoke cloud coming out of my tail pipe.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Jan 2006
    O.K. No oil in the intake pipe good, and I do have current to the pump so bad pump. It will be here Wed. evening. Glad I do not have to take the intake side off again.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
