how long would it take to R and R the converter and install the corvette Servo. can the stall be done with the trans in the vehicle, or do you have to take it out
05 5.3 RCSB, K&N CAI 77, MSD 8.5's, NGK's, NELSON TUNE, 2"-4" G-Force, HKR Max Flow, TB STALL, 28k Cooler, Vette Servo, 160 Stat, Xenon lamps EveryWhere, 10k H.I.D's, Smoked LED 3rd brake Light, Smoked Tail's, 15% Tint, 45% WS Tint
1967 Nova 358 ci Dart Pro 1 Heads Port matched to Vic. jr, 250/256 solid cam, Hooker Headers ceramic coated, Super Street Fighter Stall, Hipsters Transbrake, 9 inch w/ 4.11's, 26x10.5 Et streets, Lo-pro Caltracs
A friend and I did my converter a few weeks ago. If I remember correctly, it took about 4 hours... It really wasn't that bad considering that he had done it before. Still I'd say 6 hours with no experience...
Guys, you can go purchase 4 starter bolts and install them in the transmission to engine and use them to slide the trasmission back to install the converter. This is much easier when you go stab it back up cause the bolts keep the tranny aligned. Will have to take off the Y pipe to let the engine hang on cameros...not enough room to slide back. Works great on a truck!
Make sure you get the coverter installed all the way, usually 2 'clunks' heard/felt...you should not be able to put your fingers behind the converter on the sides...close clearance.
'-05 people haulin' 5.3 crew cab. Nelson Tuned! 17.4MPG @ 75MPH...SLOW, but not bad.
