Results 1 to 10 of 19
Thread: LS7 Heads
    Apr 2005
    Question LS7 Heads
    will LS7 heads bolt on a 6.0 block & reuse LQ9 accessories?
    Gone, but not forgotten!
    wondertruck Guest
    yes, they should bolt on, however you will need an ls7 intake manifold and fuel rails etc. really way overkill
    Apr 2005
    Quote Originally Posted by wondertruck View Post
    Thank you.
    Apr 2003
    Mansfield, Texas, USA
    Exclamation
    Also you'll destroy any low speed power you have due to the volume of the runner and the intake valve diameter.
    wondertruck Guest
    not really any loss that you will notice, most tests show 10-15rwtq losses down low over setups formerly with LS1/LS6 heads. and all that could be changed with a different manifold with properly sized plenum and/or runners.
    With his forced induction it may not be any issue at all.
    Get your shopping buggy ready for heads, 8 new rockers, not sure if you need different pushrods but don't know for sure, L76 or L92 intake complete with fuel rails, injectors and throttle body. Surely you can transfer your current injectors to the new fuel rail.
    Apr 2005
    Thanks for the info guys. That is way more involved than I want. I will get my heads reworked, or get some Patriots or something.
    Jan 2006
    SC the chamber are to small. They are like 35cc. Try the L92 heads,I think hey are like normal 6.0L heads on the cc size.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    San Antonio, TX
    Depends if you're staying forced induction or not.
