Results 1 to 8 of 8
Thread: tail gate problems
    Sep 2006
    Coon Rapids, MN
    Like it says I am having problems with the tail gates on both trucks. they dont stay up after you open it and it takes like 6 times for it to lock. thanks for any help
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    sounds like you need to lube it. Spray it with WD40 or liquid wrench and work the latches until they work correctly then put some moly or lithium grease on the mechanisms.
    Sep 2006
    Coon Rapids, MN
    Been there done that. didnt work
    04 Grand Prix GTP
    Oct 2005
    drinking your alcohol
    driver mod??
    DamnYankee: my nana failed
    Must be time for a new truck.
    Mar 2004
    NY
    Need to replace the handle. They use nylon washers between the hinged parts now so they do freeze up.
    2015 GMC Sierra RCSB Z71 5.3
    Jun 2007
    i actually had the same proble and i took it all apart and lubed t s out of it and made all parts work before i put them back in,work them back and forth ,all moving parts check em as you tighten up.latches handle arms etc,good luck.
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jul 10 2007, 09&#58;31 PM) [snapback]99174[/snapback]</div>
    ... lithium grease on the mechanisms. [/b]
    I am with Red--use some lithium grease. The spray on lubricants will dry up very quickly in your climate. Grease those bastards up really well.
