I just finished installing my stock thermostat back in my truck to see the difference between the stock and 160* stat's. The truck didn't sound as loud now with the stock stat and you can barley hear the cam because the trucks temp. is higher now. I'll post results on the gas milage if it improves later and if possible i'll try to make a pass at the track to see the times i hit.
