Results 1 to 10 of 13
Thread: 2001 4.8L Silverado 4-Sale
    Oct 2003
    LaPorte TX
    Sold
    Thanks
    Daniel
    __________________
    1999 Pewter Z28
    Sold - 2001 Onyx Black Silverado Stepside "Thunder"
    San Marcos Texas
    Now it comes for sale after I bought one! Bump for a friend with a nice truck!
    Jun 2005
    Cumming, GA
    Did you experience any gains from the intake manifold?
    2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
    Oct 2003
    LaPorte TX
    It's hard to say, when I took it to the track, it was a horrible night..
    no track prep.
    the track timing was off, and there was a head wind of about 15-20MPH..
    was running about .5 sec slow.
    SOTP it feels better in the upper RPMS.
    1999 Pewter Z28
    Dec 2005
    Deer Creek, IL
    What do you mean when you say it takes a bit to get it started? You have to crank a lot, does it act flooded? Also, has the motor ever been sprayed? Is it burning or leaking the oil?
    New project truck:
    '00 ECSB 4wd, 5.3, 3" body lift, gap guards, 18x9 Moto Metal 951's, 305/60/18 Mickey Thompson MTZ's
    To-do list: Built rear end, 6.0 swap with built top end, 4L80e, and a couple bottles in the bed.
    Oct 2003
    LaPorte TX
    <div class='quotetop'>QUOTE(krwyellowZ28 &#064; Jun 14 2007, 09&#58;01 PM) [snapback]96791[/snapback]</div>
    No you dont have to crank it alot.
    The truck cranks right up. but the IAC needs to be adjusted again.. not much, for somebody that wants to just jump in it, and take off you can..
    it just doesnt like to stay running after you crank it when the motor is up to Temperature. unless you press the gas, and hold it at about 1,000RPMS untill the PCM catches up.. once you do that, no problems. it idles fine.
    Simple fix.. just need to adjust the IAC to get it smoothed out. I havnt had time to do it..
    AS far as the oil goes.. It is burning it..
    no oil leaks.
    1999 Pewter Z28
    Jan 2007
    was that 13.2 before or after the LS6 intake??....thats a badass time for being tuney by LS1 edit...i&#39;m sure it&#39;ll hit better times if tuned by HPtuners....good luck with the sale bro&#33;&#33;&#33;
    12.82@103.82mph w/1.78 60ft
    TUNED BY DAN
    Oct 2003
    LaPorte TX
    <div class='quotetop'>QUOTE(lablackpearl &#064; Jun 19 2007, 07&#58;37 PM) [snapback]97247[/snapback]</div>
    before
    1999 Pewter Z28
    Oct 2003
    LaPorte TX
    Price Dropped to &#036;9,000
    here is the passenger side, there is dent between the side view mirror, and the logo
    "thunder" on the door
    1999 Pewter Z28
    Oct 2003
    LaPorte TX
    Sale Pending
    1999 Pewter Z28
