Results 1 to 10 of 11
Thread: Gen III hp ratings
    Apr 2006
    I was playin around on ebay and came across these hp ratings for gen III motors
    Check this out
    The 6.0 I figured was right but are the others really that close?
    Flowmaster, dual 3" tips, nice wheels.....just like every other '93 silverado.....
    LS1 coming soon...
    Apr 2007
    friendswood
    Thats the 6.0 out of a truck not a vette, thats why its close the lq4 is truck, ls2 is vette.
    2006 ecsb silverado, AFE Cai, Jet Maf, Pacesetter Ceramic Coated Lt's, true duals with Dynomax Bullets, cats and o2's....still emissions legal!
    "Ford...At least they circled the problem".
    Apr 2006
    Yea I know that, I've seen that # for the 6.0 before. I was wondering if the 5.3 and 4.8 really had as much power as this guy says.
    LS1 coming soon...
    Apr 2007
    friendswood
    those are engine hp not rwhp mine is rated, or i should say they told me "305" hp but its not i know, its a quick motor to say the least.
    DBYRD Guest
    depending on the truck the difference in the 6.0 and 5.3 can be a huge difference or a tiny difference. in a small truck its like night and day. the 5.3 is a great motor but the 6.0 does super with a rcsb. every mod u do to a 6.0 will have a better effect than the 5.3 imo.
    Ok, ok. I will try and dip into the memory bank here:
    1999-2002
    4.8L (LR4) 270 hp/285 ft. lb.
    5.3L (LM7) 285 hp/325 ft/ lb.
    6.0L (LQ4) 300 hp/360 ft. lb.
    8.1L (L18) 340 hp/455 ft. lb. (01-04 only?)
    02-07 Classic
    4.8L (LR4) 285 hp/290 ft. lb.
    5.3L (LM7) 295 hp/335 ft. lb.
    5.3L FF--E85 (L59) 295 hp/335 ft. lb.
    5.3L HO (L33; 05-07 Classic) 310hp/335 ft. lb. (available in EC 4WD only)
    6.0L (LQ4) 325 hp/370 ft. lb.
    6.0L HO (LQ9--VortecMAX, had special high-compression 10:1, flat-top pistons) 345 hp/380 ft. lb.
    That is as much as I know from 1999-2007 Classic. I am sure if you need the NBS hp figures, you can go to GM's website.
    May 2007
    Las Vegas
    <div class='quotetop'>QUOTE(txarkitekt &#064; May 18 2007, 07&#58;55 AM) [snapback]93880[/snapback]</div>
    1999-2002
    02-07 Classic
    That is as much as I know from 1999-2007 Classic. I am sure if you need the NBS hp figures, you can go to GM&#39;s website.
    here is a good site if you want to look up info on trucks and engines..
    http://www.internetautoguide.com/car-speci...p/32/index.html
    02-07 - the LQ4 6.0l is Power: 300 HP SAE @ 4,400 rpm; 360 ft lb , 488 Nm @ 4,000 rpm
    2006 chevy 1500hd CC 6.0L
    Headers
    K&N intake
    Flowmaster
    Nelson tune
    Ls1 fans
    6 inch CST lift
    18 inch kmc xd series
    Aug 2005
    Houston,Texas
    THE 04 5.3 S PUT OUY OUT 295HP AND 330 FT/LB 0F TQ , 99-01 LQ4 300HP AND 355 LB/TQ. tHE 02 AND UP LQ4 PUT OUT 325HP AND 370FT/LB TQ ACCORDING TO THE LS1/LS6 BOOK BY WILL HANDZEL. mY 99 5.3 ONLY PUT OUT 265HP AND 320 FT/LB TQ
    99 ECSB 5.3 LS6 CAM AND SOME BOLT-ONS BEST TIME 13.6@97MPH
    http://i104.photobucket.com/albums/m...wTRUCKS008.jpg
    May 2007
    Las Vegas
    i have a lq4 in mine and its rated at 300 hp and 360 tq
    5,967 cc 6 liters V 8 front engine with 101.6 mm bore, 92 mm stroke, 9.4 compression ratio, overhead valve and two valves per cylinder LQ4
    Unleaded fuel 87
    Multi-point injection fuel system
    25.9 gallon main unleaded fuel tank
    Heavy duty engine cooling system
    Power: 224 kW , 300 HP SAE @ 4,400 rpm; 360 ft lb , 488 Nm @ 4,000 rpm
    Headers
    K&N intake
    Flowmaster
    Nelson tune
    Ls1 fans
    6 inch CST lift
    I just now realized that GM let their little 5.3L crank out more power than the 6.0L...the 5.3L HO (L33) made 310hp/335 ft. lb., but it was available in EC 4WD only. That is 10 more hp and 25 ft. lb. less torque--which isn&#39;t a lot. I am not sure where everybody got their numbers from--I just used what was stored in my brain--but....I just now looked up this awesome link and found out some really neat info and history on the LS engine...
