Results 1 to 8 of 8
Thread: gas tank probs
    Oct 2005
    Houston, Tx
    wifeys 01 tahoe. has ben having a problem time to time. with the fuel gauge. when i fill it up . it goes to empty the low fuel light came on. i started driving it went off. went to the car wash put in park washed it. empty ..lo fuel light on. started drivng went to full light went off. it did this a couple weeks ago for the first time. any suggestions?
    <div class='quotetop'>QUOTE(TXcrew &#064; May 9 2007, 11&#58;06 PM) [snapback]92959[/snapback]</div>
    wifeys 01 tahoe. has ben having a problem time to time. with the fuel gauge. when i fill it up . it goes to empty the low fuel light came on. i started driving it went off. went to the car wash put in park washed it. empty ..lo fuel light on. started drivng went to full light went off. it did this a couple weeks ago for the first time. any suggestions? [/b]
    Mine does the same thing. It is probably either a bad ground somewhere or a bad electrical connection at the fuel pump for the float that registers the amount of fuel in the tank. I wouldn&#39;t worry about it too much, but I am sure if you drop the tank and spray WD-40 on the electrical connections, it would solve the problem. The connectors are probably dirty or loose...
    Apr 2006
    <div class='quotetop'>QUOTE(TXcrew &#064; May 9 2007, 08&#58;06 PM) [snapback]92959[/snapback]</div>
    Mine does the same thing, from what I&#39;ve seen it&#39;s a relatively common problem with the sending units. Mine is worse when I&#39;m below a 1/4 tank, fill it up and it bounces around a few times and reads ok again. Every now and then it drops and comes back up to the correct level. It&#39;s annoying, but it still works most of the time so I&#39;m not ready to pull the tank yet.
    '99 GMC RCSB
    3" Body lift, 4" Rancho lift, Fox shocks
    36" BFG All-terrains
    LQ9 6.0L swap, gt2-3 cam, longtubes, LS1 fans, Nelson Performance tune
    4.8 gears/Eaton posi
    Built 4l65e
    Custom paint, roll pan, filled tail lights, relocated tail gate handle
    Future mods:
    Boost!!
    <div class='quotetop'>QUOTE(tenshikurai &#064; May 10 2007, 04&#58;06 PM) [snapback]93027[/snapback]</div>
    common problem with the sending units [/b]
    Thank you&#33; Freaking sending unit....I was sitting here thinking to myself...WTF is that called...so I typed "electrical connection at fuel pump that connects the float..." or something like that. Sending unit is much easier to understand. Yeah, mine does the same thing---empty, full...empty, full. At the snap of a finger...it doesn&#39;t float around--real quick up and down... I am not worried too much about it now. If my fuel pump ever goes out, I will replace it then....
    Apr 2007
    nova scotia, canada
    yeah mine does the same thing
    2000 silverado 4.8 5-speed
    <a href=http://i24.photobucket.com/albums/c9/chrispond/DSCF0112.jpg target=_blank>http://i24.photobucket.com/albums/c9...d/DSCF0112.jpg</a>
    Oct 2006
    common with the chevy trucks and suv&#39;s from like 98-03 or so i&#39;ve been hearing. My 00 silverado and my girl&#39;s 03 s-10 both do it
    2000scsb silverado, &#39;02 5.3L with Comp Cams custom ground LS1 cam 222/224 112lsa +2deg. 581/581 , &#39;01 LS1 heads decked 0.010" ported, Comp beehive valvesprings, pushrods, shims, pace setter longtubes, no cats, Nelson tuned. AuburnGear Pro series LSD, 4L60E built with 2k rpm stall, corvette servos and raybestos clutches..... Fun enough...... for now
    Mar 2006
    Indy
    Mine does it. The mechanics at work say the old style has contact points that get worn down on the float lever. Causes a bad connection and does that. Got to get a new one. Or just live with it like im doing.
    Sep 2003
    I see this all the time
