Results 1 to 8 of 8
Thread: Traction and Tires
    I got a few traction questions.
    Will a 15" wheel fit on an 01 with disk brakes?
    You think I can get noticable grip improvements upgrading my tires from a 255 to a 285 width?
    Also, I was going to fab up some CalTrac bars. For anybody that owns CalTracs, it doesn’t even look like there is enough room for the 2 plates on either side of the Front of the Leaf Spring. Am I missing something?
    thanks for the help
    01 RCSB, 5.3, TR224/112
    4.10 w/ Auburn
    3200 Fuddle, HD2, Vette Servo
    Nelson Tune, LT Headers
    <div class='quotetop'>QUOTE(01silverado &#064; Apr 23 2007, 11&#58;36 AM) [snapback]91010[/snapback]</div>
    thanks for the help
    It all depends on the inside dia. of the wheel compared to the caliper housing/bracket. I tried putting 16" on mine and it rubbed the caliper bracket.
    You will get a noticeable improvement going to 285s, but may still have some traction problems...
    Apr 2005
    Go to 305&#39;s.
    Caltracs will fit. You have to take out the factory bushing & steel sleeve and use the new ones with the kit.
    Gone, but not forgotten!
    Does anybody make a 305 that is close to 30" diameter? I cant find any.
    4.10 w/ Auburn
    <div class='quotetop'>QUOTE(01silverado &#064; Apr 23 2007, 05&#58;51 PM) [snapback]91081[/snapback]</div>
    295-45-20 is about 30.5 and lighter than the 305 look at tire rack in the specs side.
    or this link if it works
    http://www.tirerack.com/tires/Spec.jsp?mak...yes&place=7
    <div class='quotetop'>QUOTE(zeake &#064; Apr 23 2007, 07&#58;43 PM) [snapback]91109[/snapback]</div>
    I need some 305s for stock 16" wheels though
    4.10 w/ Auburn
    Jun 2005
    <div class='quotetop'>QUOTE(01silverado &#064; Apr 24 2007, 12&#58;10 PM) [snapback]91242[/snapback]</div>
    I could be wrong but I doubt you&#39;ll find (or want) 305s to fit on a stock 16" rim. Stock rims are like what.....7-7.5" wide? I&#39;ve got 285s and the minimum wheel width is 8"; 8.5 recommended.
    &#39;02 Silverado Z-71, STS Turbo @ 10psi, TRT Custom FMIC, Comp 222/218/115 cam, Patriot Gold Dual Springs, Hardened Push Rods, 60# injectors, 160 Thermo, FAL E-Fans, Nelson Harness, Yank 2600, Built Rock On VacMod 60E Transmission,Walbro 255 fuel pump, ASP Underdrive pulleys, Gibson Shorty Headers all polished up with a Nelson Street Tune
    Nov 2005
    I got me some 325/50 15in E/T steets for my 78 beater. I hope they hook&#33;&#33;&#33;
    SOON TO COME!!!!
