Results 1 to 3 of 3
Thread: Got my FMIC Installed Today!!
    Spring, Texas
    I finally got my IC installed today but now I need a little help. (I'll post pictures of the install) I called Billy (TRT) and he told me what I would need to extend the intake temp wires from the MAF sensor and I forgot what it was. I know he said it was something that's for the f-body but can't remember exactly what it is. Can somebody refresh my memory for me please maybe with part numbers, if you've got 'em??
    Right now my truck is running pretty slow since the PCM can't register the lower intake temps. Can't wait to get everything corrected.
    Dec 2003
    Newark, Tx.
    get intake temp sensor, gromet, and connector from g.m.
    Extend the brown and tan wires from the maf conn. to where you want the IAT. It should be in the last pipe in front of the throttle body.
    Spring, Texas
    <div class='quotetop'>QUOTE(trtturbo &#064; Apr 19 2007, 10&#58;26 PM) [snapback]90665[/snapback]</div>
    Thanks&#33;&#33;
