Results 1 to 7 of 7
Thread: Fuel pump and tune ???? ALLEN Help
    Mar 2007
    Pittsburg, TX
    Thumbs up
    I am helping 2500HD6.0 put his STS kit on and he just ordered (overnight) a 255 fuel pump. His new tune is showing up to day but that is for his stock fuel pump with 42# injectors.
    (He won't run it to hard on the stock pump for fear of going boom)
    If we put the new fuel pump in before he gets a tune for it will this hurt anything?
    Does he have to retune for the new fuel pump before running it hard? (Think safely it will only take a few days to get a new tune but that’s along time when you have turbo noises following you around.)
    My Ride: 2006 Chevy Vortec Max, LQ9, 4X4, no cats, 50 Series Flowmaster in factory pipe, 20"s, C.A.I., Custom tune by Dustin at TRT Performance
    San Antonio, TX
    <div class='quotetop'>QUOTE(06BLACKMAX &#064; Apr 6 2007, 01&#58;16 PM) [snapback]88819[/snapback]</div>
    (He won&#39;t run it to hard on the stock pump for fear of going boom)
    You can install the fuel pump before I tune for the new pump. The tune he has now was tuned for: removing the magnacharger and having 42lb injectors. I did not tune for the turbo becuase his retune form said only removing charger and keeping the 42lb injectors, so a/f ratio and timing are different, DO NOT MAKE ANY BOOST&#33;&#33;&#33;&#33;
    His truck has an NA tune, high timing and lean. A turbo tune is rich and lower timing.
    He&#39;ll be able to drive it down for a full tune, just don&#39;t make any boost or kaboom.
    If he needs a new tune for the turbo, we can send him a retune.
    let me know,
    allen
    Apr 2005
    PM sent for help
    2500HD 6.0 - K&N filter, TB bypass, Ported and Polished TB, no cats, SD Tune BY Nelson, 42# injectors, STS, T-67 .96 A/R, @5psi Walbro 255lph, Air to Water Intercooler, coolingmist kit @ 6ghp
    CJ-7 - K&N, TBI 350, dana44 front locker, 9" ford rear spooled three link, 38.5" SS, bead locks,and tons more.
    http://i44.photobucket.com/albums/f4.../100_04079.jpg http://i88.photobucket.com/albums/k1...eepcroped2.jpg
    San Marcos Texas
    Just leave the intake piping loose so it will leak if it tries to make boost. You need a wideband&#33; Oh and pics please?
    Jan 2006
    <div class='quotetop'>QUOTE(GMCwantsLS1 &#064; Apr 6 2007, 06&#58;47 PM) [snapback]88857[/snapback]</div>
    PICKS PLEASE, WE WANT TO SEE. YOU ARE GOING TO LOVE THAT TURBO-MUCH BETTER THAN THAT MAG. NO BOOST UNTIL YOU GET THAT TUNE&#33; YOU WILL BE BUYING A MOTOR TO GO WITH THAT TURBO.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Mar 2007
    Pittsburg, TX
    The install pics are under the I wanna go fast post.
    Mar 2007
    Pittsburg, TX
    Hey guys we have a serious problem. 2500HD6.0 made it home but now he is blowing fuel pump fuses like crazy&#33;&#33; He can put a new fuse in and the truck will start but as soon as he moves the gas pedal the fuse blows. WTF is going on with it&#33;&#33;&#33;
