<div class='quotetop'>QUOTE(Jamest @ Apr 6 2007, 08:42 AM) [snapback]88792[/snapback]</div>
IS THAT AN OIL SPOT BESIDE YOUR TRUCK AND UNDER YOUR TRUCK? I WAS ON YOUR SIGHT AND GOT RAN OFF FOR DOING WHAT YOU ARE DOING, SO KEEP THE HORN CRAP OFF THIS SIGHT. IF YOU WERE A GM FAN AT HEART YOU WOULDN'T BE ON HERE BOASTING YOU RAMBAG. YOU BETTER GET THAT OIL LEAK FIXED BEFORE YOU GO BOOM IN THE 1/8TH. JUST MY
JAMEST
http://forum.ls1truck.com/index.php?showtopic=11100
ENOUGH SAID CHECK OUT THIS TRUCK FROM TRT TURBO.
JAMEST
12 Sec. Club! SOLD
SOLD***
