Results 1 to 10 of 28
Thread: e-fan owners
    Oct 2005
    drinking your alcohol
    ok i have a dual fan spal setup that i would like to mount to my radiator once i get my new fan harness and tune worked out......
    but i have the old clutch fan on there now... and the fans did not come with any mounting hardware... i bought a set of mounts and when i said they were going on a dual setup the guy told me that most people with dual fans fabricate their own mounts...
    so my question is... how the hell do you do it?!?!
    any pictures and or instructions would be wonderful
    DamnYankee: my nana failed
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(TxStVanWilder &#064; Mar 28 2007, 01&#58;09 PM) [snapback]87583[/snapback]</div>
    so my question is... how the hell do you do it?&#33;?&#33;
    Piece o&#39; cake man. The bottom of the fan &#39;frame&#39; will just sit in a channel. For the top, fab two pieces of flat stock aluminum or similar. Use the stock bolt holes.
    Oct 2005
    NICE&#33;&#33;&#33;&#33;&#33;&#33;&#33; thanks Moze
    seems pretty mickey mouse enough to do for me.... now i have something to do tonight when i get home.... hmm or maybe i should do this while im "working" today :laugh
    hmm now that i look at mine it will take a bit more "fabricating on mine....
    i dont have an much "solid" area on mine that i could bolt to..... ill take a pic and upload it to show you what i mean
    ok here is a pic of what i am working with..... where my hand is pushing through... that area is all rubber flaps that let air flow through.... so mounting like your will be a difficult situation.... ill have to figure something out
    <div class='quotetop'>QUOTE(TxStVanWilder &#064; Mar 28 2007, 01&#58;59 PM) [snapback]87588[/snapback]</div>
    How I did mine might work for you. I went to the scrap yard and found nice size piece of 90 deg aluminum. I bolted it to the top of the Fans then to my truck.
    lol missing a few bolts
    Mar 2006
    Mesquite
    No problem. What year is your truck? Not sure if it will drop in same as mine did or not. It&#39;s a cake install.
    Oh, and if need be - zip ties are your friend.
    Nice - what are they out of?
    Oct 2005
    mine is an 02....
    it should fit in similar to yours... the only kink in the plan would be the spot to place a bolt in the fan itself similar to yours.... theres not much room....
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(TxStVanWilder &#064; Mar 28 2007, 02&#58;04 PM) [snapback]87592[/snapback]</div>
    mine is an 02....
    I bet you could get a bolt through the wider vertical plastic piece under your thumb.
    Oct 2005
    yeah that might work... its only about 3/4 inch wide... my concearn is i really dont want to bolt to a weak point on teh fans and snap it from vibration down teh road.....
    THAT is where zip ties win
    ill just have to do some trial and error tonight before i head down south
    Mar 2006
    Mesquite
    I&#39;m trying to think - I may have some flat stock at home, can&#39;t remember though. Give me a shout if ya need any parts. I know I have some aluminum angle (1"x1" and maybe some 1½"x1½").
    Oct 2005
    im out here at the airport doing a whole lot of nuthin... so im gonna go troll around the back of our shop and see what i can dig up.... ill give you a shout if i need any yankee help
