Results 1 to 8 of 8
Thread: 97 vortec question
    Aug 2006
    canada
    Anyone know if a 97 L31 computer will run a multi port injection such as a stealth ram or the like, on top of
    the intake there are eight seperate injector pins and the wiring diagram shows it as firing eight seperate
    times, I really want multiport but don't want to hack up the trucks electronics and everything has to work, not looking for a ls 1 swap this time around. thanx.
    97 RCSB, all slicked out front and back, 5 and 7 drop, 20's, sometimes 22'shttp://s103.photobucket.com/albums/m...h_IMG_1069.jpg
    May 2004
    Yes it can. You might want to try the vortec marine manifold.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Aug 2006
    canada
    Thanx nitrous, I saw all the info on the marine swap on fullsize chevy.com those guys are pretty pumped on it, I figured it could be done but kind of needed to here it from some other people before I go rip up a perfectly good l31 truck. I think I'll go with the stealth ram or a single plane and throttle body for power potential though, thinking of some nitrous or twin turbos funds permitting of course, thanks again.
    May 2004
    You should be able to get an adapter harness to run the injectors so you don't have to splice into the factory one.
    97 GMC, 2002 LS6.
    Aug 2006
    canada
    Who would make such an adapter? S&P maybe? The less butchering the better.
    May 2004
    I would think you can buy the injector harness form a marine dealer or GM. Check this link out and give GM a call. Vortec Marine Engine
    97 GMC, 2002 LS6.
    Aug 2006
    canada
    Engines in, and runs with the factory computer, tuning required ofcourse. used the jet dst. Seems like it's gonna work pretty good. once everything is all set up, I plan on doing the 411 computer swap for a little more rpm potential, the motors good for it, sounds sweet.
    May 2004
    Great news!!!
    97 GMC, 2002 LS6.
