Results 1 to 9 of 9
Thread: Tach install
    Mar 2006
    Hey guys I got a tach for the truck and am not sure which pin coming out of the pcm is the tach wire. I think it is white. Is this the best place to tap into the wire or should i look for it behind the gauge cluster or something. Any advice you can give me on this install would be great....thanks for your time
    Jarrod
    Dec 2003
    Azle,TX
    <div class='quotetop'>QUOTE(carfreak07 &#064; Feb 7 2007, 09&#58;33 PM) [snapback]82597[/snapback]</div>
    Jarrod
    I think it is whitecoming from the PCM harness and if your tach has cylinder settings you have to set it to 4 cylinder....signal is drivers side cylinders only. Google the year model truck you have and what brand tach and youll find lots of info.I got mine used,its an older one but works perfect&#33; Hope this helps a little
    Vortec Performance Tuned
    Sep 2004
    Breaux Bridge, LA
    white wire behind the cluster.
    cut the wires on the tach to make it a 4cylinder and your...
    good to go&#33;
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
    Mar 2006
    <div class='quotetop'>QUOTE(bluecajun5.3 &#064; Feb 8 2007, 12&#58;38 AM) [snapback]82615[/snapback]</div>
    good to go&#33;
    ok sounds like a plan....thanks alot guys......do you guys have any pictures of your tachs mounted.....I prolly should be putting this tach in the ss instead of the truck since it is a six speed and the truck is an auto but the escalade cluster only goes to 6000....and besides that the big tach will give it some character that the ss doent need as bad&#33;
    Sep 2006
    Coon Rapids, MN
    <div class='quotetop'>QUOTE(carfreak07 &#064; Feb 8 2007, 01&#58;49 AM) [snapback]82623[/snapback]</div>
    i love mine where its at what would be better go from the pcm, like i have it now or from the cluster. just askin
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    Jan 2007
    San Antonio,TX
    or u could have done it from ur pcm the pin would have been R10 and wit the white wire.
    92SHORTBED
    Jan 2007
    San Antonio,TX
    4rm the pcm because u know 4 sure whats going where&#33;&#33;&#33;&#33;&#33;
    92SHORTBED
    Sep 2006
    THE 405
    how come I can&#39;t get my tach to work? I have it tapped into the white wire behind the cluster but nothing happens...any suggestions. This is the second tach I&#39;ve tried. I&#39;ve put it on every different cylinder selection
    midweststreetcars.com
    Aug 2006
    LAKECHARLES, Louisiana
    <div class='quotetop'>QUOTE(DozerDan &#064; Feb 15 2007, 09&#58;41 PM) [snapback]83447[/snapback]</div>
    If your tach has read back and such features make sure your power wire is hooked to a good ignition source.And also that you have a good ground.
    2000 Chevrolet Silverado, 4.8L, K&N polished intake, 4.10 gears, 20x9 KMC SS on front, 22x10 on rear, Dual style pillar gauges, steel cowl hood, 2" rear drop shackles, true duals w/IMCO extreme mufflers w/dumps at rear end, SLP headers. Cam and nelson tune soon to come!!!!!
