Results 1 to 4 of 4
Thread: 4l80E Swap, TIPS,TRICKS, SITES????
    Jan 2007
    California
    I think after finding out prices from FLT and a local tranny shop, that i just don't have that kind of money right now. I was looking at Jim Parish's site last night, reading his different pages on what he did to his truck. Driveline wise he had previously had 60E's for tranny's and broke them all. I know now he has a fully built FLT 80E, but he had mentioned that he was tired of breaking his 60's so he did the 80E conversion, he had bought one out of a junkyard with like 50 or 60,000 miles on it, put the transgo, and it survived his application for some time, and he recommends doing that swap and if it worked for his HP then it will surely work for mine, and i am for sure doing a 6.0 swap in the near future, so since the truck is out of comission, i say do it now. I know it will just take some searching on here and PT.net for HOW To's on that swap, but just wanted to let you guys know that this is what i want to do, and F%$# the 60E and the B&M verter. I want the 80E and a Yank 2600 or 3000, do it right or don't do it at all. Any tips on doing this swap, any good sites with step by step, what i need to buy, electrical hookups, Shim, Driveshaft lengths, Crossmember INFO. ANything would be great.
    2004 Sierra, 5.3L V-8, K&N Intake, AirAid TBS, TB Bypass Kit, HP Tuners, Transgo HD2 Shift Kit w/ vette servo, Dynatech LT's, LS1 Fans, 3:73's, Hanger and Shackle Kit, 6500K HID's, 22" Velocity Wheels.
    http://www.cardomain.com/ride/2492197
    http://i42.photobucket.com/albums/e3...life/Sig_1.jpg
    Aug 2005
    St. Anthony, Indiana
    Ft. Worth, Tx
    You will need the flex plate, spacer, wiring harness adaptor, fab a crossmember, and tranny cooler lines. You can pretty much get what you need from the junk yard. Use the existing crossmember to fab the new one. cut your lines and extend them. And you can get the harness from speed engineering or speartech.
    90 GMC RCSB Forged 370 and Built 4L80E from the VHO going in slowly but surely
    89 fox body notch... No motor or tranny mod but a narrowed 9" w/ 35 spline axles and a spool!!
    2011 Tundra CM 4x4...
    Zanesville, OH
    I think I'm getting mine from this place. If you get the hp version they give you your choise of verters.
