Results 1 to 5 of 5
Thread: made cam install tool
    Oct 2003
    San Antonio TX
    I'm not going to pay $84.00 for the JPR cam install tool. So I made one. Total cost $4.50. Here's what you need.
    2 1/4 inch brass tubing from hobby store ($2.25 each part#K&S1149)
    cut them to the lengh of your cam (20in.) with cutoff wheel
    bend one end at a 90deg. 1 inch up flat with pliers
    you have a cam install tool
    Now when you do a cam swap, spin the old cam. Then slide this tubing in the ports beside the cam, the left and right sides.. NO WAY the lifters will slide down now. So swap new cam with old new one. And pull the tubing out, and go on from there.
    2003 RCSB 4.8L 5speed, BLACK
    3.42, AIRAID, loudmouth exhaust
    Nelson Performace Tune
    2000 vett cam
    160* stat
    et 14.80@94mph
    May 2003
    you have lost me. pic?
    Oct 2003
    San Antonio TX
    http://www.ls1howto.com/index.php?article=23
    They have a pic of the JRP install tool. I made the same thing for my cam, but out of brass.
    2000 vett cam
    160* stat
    et 14.80@94mph
    May 2003
    gotcha ! I just used the cross your fingers method ! I dont remember two holes being there to slide the tools in though.
    Apr 2003
    South MS
    I borrowed the JPR tools from a friend but they look very easy to make out of some aluminum bar as well. Yea, I would't have paid $90 for them either.
    2000 Silverado, RCSB, 2wd w/ a few mods.
    Best 1/4 ET: 12.09@111.22 (old 5.3L H/C/N2O setup)
    WRE 370 and Kenne Bell 2.8L installed and breaking trannys.
    2001 Tahoe LT 4wd
    Stock, daily driver and tow vehicle.
