Results 81 to 89 of 89
Thread: Building Iron LS1
Threaded View
    Mar 2010
    Paris, TX
    Building Iron LS1
    Since the motor in my truck is questionable at the moment. Has had metal shavings on drain plug magnet last three oil changes. More every time I change the oil. I have decided to build an Iron Block LS1. Most of the parts are here and I decided to start a build thread. Looking at 11:1 CR with 8.8DCR and a quench distance of 0.030. I know that is on the limit of pump gas but I would like to run e85 once it is available in my area.
    5.3 Block Bored To Fit Stock LS1 Pistons
    Ported Oil Galleys In Back Of Block and Oil Pan
    Stock Crank Cut .010 On Rods And Mains Due To Lifter Failure In Donor Motor
    ARP Rod Bolts
    Clevite Bearings
    Recondition Stock LS1 Rods
    New Gm Stock LS1 Pistons
    Ported (By Me) Stock 706 Heads
    Comp Cams 219/227 .607/.614 Installed 6°Retarded To Keep DCR In Range
    Comp Cams New Revised 918's
    LS7 Lifters
    Comp Cams 7.4 Pushrods
    Melling Oil Pump High Volume Thinking Standard Pressure Spring Come With Both Springs
    42# Delphi Injectors
    Stock Ported Intake and Throttle Body
    Keeping My EBay Headers
    Running Trailblazer Stall For Now
    I am also going to rebuild my transmission while I have my current motor out for the swap. Let me know what you all think of the parts and what power it will make.
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
