Page 7 of 16 FirstFirst ... 5 6 7 8 9 ... LastLast
Results 61 to 70 of 158
Thread: New Life for a truck passed its prime
    Nov 2009
    Fort Smith, Arkansas
    Since Im not banned yet...
    Made some good progress tonight. My friend had a spare PS pump so I got that taken care of. Still need a pulley though.
    We put the truck up on the lift and after some cussing, grinding, and swivel breaking we got the motor mounts changed. I cleaned up the engine bay using super clean and a rag. Then, I took some black engine paint and painted some bad areas. To really do it right it would have to be dissasembled, sandblasted, then painted. But I really dont want to dissasemble anything more than it already is because that will prolong this build by another week atleast. Plus, this is no show truck. It doesnt look great but it looks better than before.
    I need help with trying to figure out which wire I connect the speedo output from the ecm to. I have a couple diagrams for my instrument cluster but still cant figure out which one is the right one. My wiring buddy insists on not using the DRAC whatsoever which I guess I can do since Im running DBW. As long as the signal from the ecm is compatible with my speedo it should work.
    Got the pedal mounted. We had to shorten the arm and drill a new hole in the pedal mount to get it where I wanted it. Its still not perfect but I can live with it.
    My headers are gonna be ok. They need to be touched up but dont look too bad.
    I took the 4l60e flywheel off and put the 4l80e flywheel and spacer on but I really dont know if I put it on right. Please check the pics and let me know. Do I have too many parts there? Too few?
    Then I attempted to mount the motor in place. For some reason I couldnt get the mounting cups to line up with the mounts. I had this same problem last time I put in the mock setup but the very first time I put in the mock setup it went in like butter with no problems at all. I can get either one of the mounts lined up but not both sides at once. I tried using straps to lift either side independently but couldnt get it. They are always bout 1.5 inches off. I should have taken pictures of this problem but I had to leave suddenly and couldnt.
    This is how I left it. Its still not mounted in place but atleast its in there. My converter should be here today so hopefully I can put it in tomorrow night. (Since I have to work tonight).
    Gramercy
    sounds like me.
    how are you gonna get the PS pump off if you cant get the pulley off? the bolts come out the front of the pump an the pulley is in the way. cut it off with a sawzal an then put a new pump lol
    2008 GMC CCSB 6.2/6L80e swap
    Nov 2009
    Well we already got the pump off. We up the pulley enough trying to get it off that there was enough room to get the bolts out.
    Dec 2004
    San Antonio, TX Area
    Just fyi...
    1. Expletives
    No swearing is allowed. If you are not sure if a word is allowed it would be better to do without. If you use symbols in place of a word that is not allowed and it is clear that the word meant is in violation of these rules, you will receive an infraction. If you receive 3 infractions within a 30 day period you will automatically be banned from use of this website for a period of 30 days starting from the date of the first infraction received. If you feel you have received an infraction without due cause you may appeal the infraction by emailing admin@ls1truck.com. You will receive a confirmation email confirming that your case has been received with a case number and a form to fill out. Any form that is not completely filled out in all fields will be considered a statement of withdrawal of the case and an admission of guilt. A decision will be reached within 30 days of the date the email is received by an unbiased third party with no association to this website, its owners, or any subsidiary of this site. If found innocent any and all charges incurred by the investigation will be paid in full by this website and normal membership will be restored/reinstated immediately. If found guilty you will be held liable for any costs incurred by the investigation, independent third party costs or any debts or fines that may accrue from the investigation. If found guilty you will have 30 days to pay in full any balance owed. After 30 days a late fee of 12% will be added to the cost of any debts or fines. If debt remains unpaid after 60 days the debt will be turned over to a debt collection agency and all legal recourse of collecting this debt will be used. Any information considered as private (email, address, SS#, etc...) that is held by this site or any site affiliated with this site will be used in an attempt to collect any debts, fines owed. This process is necessary to keep this site fair for all peoples of any age group regardless of race, religion, sexual orientation etc...
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Nov 2009
    Are you serious? Please dont make this site like FSC. I thought this was better than that! If you dont like how I post then ban me. I dont give . I post my questions so others can find answers later.
    Gramercy
    well honestly i had the same problem. i wish i would have grinded the tabs off the frame mounts bc they would get caught on the clam shell mounts. the flywheel i have no idea
    do a search in the LSx section an see which one Redheartbeat says to use. or go to my thread an search in it if your able. i think Redheartbeat said it in mine too. i cant remember anymore
    you have too many extensions on the flexplate. The spacer between the flexplate and crank is correct. The 60e style extension is not needed with that 80e spacer and flexplate. You are going with an old school 80e convertor, correct? Try bolting it to the the flexplate to check fitment.
    Nov 2009
    Thanks for letting me know on the extensions. How do I get the 60e extension out? I put some bolts in it and jerked and it didn't budge so I assumed it was meant to stay.
    I am using a custom made 9.5" converter with the mounting ring on it. I will test compatability with the flywheel tonight.
    Still not sure what to do about the engine mounts.
    The grey looking extension in the photo will probably have to be knocked out from the other side of the spacer with a punch or press. The engine mounts, I've had that issue numerous times. Bolt one side in and then take your engine hoist and jack the engine up on the side that is bolted up, it will slide up inside the mount and make the other side bolt easier to install. You may still have to pry the rubber part of the mount higher. There are redesigned motor mounts that make it simpler to install the engine, it mounts the cups inward, lower, a little and probably raises it a full inch in the engine compartment.
    Nov 2009
    Oh so it's the gray plastic thing that has to go? I see. Thanks for the always helpful advise. It's good to know that nothing is wrong with the mounts. I just need to work with it more. I'm glad I didn't finally get it now that it has to come back out lol.
