Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 59 of 59
Thread: Muffler Options
  1. #51
    Feb 2009
    Wichita Falls, TX
    Quote Originally Posted by RPM Graphics View Post
    when you say "big" what size exactly?
    this is my daily so i don't want anything too loud.
    I posted the size on the last page.
    "So I bought the 30x8x5 single 3in/out magnaflow
    I'll never buy another muffler except the big case magnaflows.
    I had the 30x11x5 single 3in/out magnaflow on my old H/C 5.3 with LT's and it sounded awesome. Quiet at cruise and opens up at WOT."
    Hope that helps
    Alex
    02 Chevy RCSB V6 -> H/C 5.3L SOLD
    03 GMC RCSB 5.3L CAI,Tune,3/6 drop
  2. #52
    Jan 2012
    Corpus Christi, TX
    Quote Originally Posted by DjGreggieP View Post
    Did you leave the cats or pull them as well?
    Left cats exhaust is all stock just replaced muffler. It also seems to be getting louder. Has real deep throaty sound when driving normal
  3. #53
    Sep 2010
    North East Ohio
    I installed the 18" case magnaflow and have LT with a highflow cat and sounds awesome. Way better then the flowmaster I had. Its not stock sound when cruising but sounds really good. At WOT or under load it sounds amazing
    2010 Silverado 4.8 Ext Cab 4x4
    Cam, Stall, 4.88's
  4. #54
    Sep 2010
    Manitoba
    Hey Chri$09 can you post up some pics of your exhaust setup?
    Sounds exactly what I was planning. Would like to see how you got a 4" connected.
    2000 Chevy rcsb 5.3, 4L80E, 3.43 G80, P&P heads, Isky tripple 12, EFI LIVE
  6. #56
    Quote Originally Posted by if99 View Post
    yes i can post pics for you soon. its simply a 3" to 4" adapter that looks like the beginings of a eco-tip but not chrome. then the 4" inlet/outlet spintech and we used mandrel (sp) bent diesel tailpipe to finish out to the back.
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
  7. #57
    now when i get my headers the next part will be redone and replaced to make it look more pretty and straight. this was just to get me by till then.
    over all im please with the tone. it was really tight trying to get the tail pipe done where it cleared everything. as i stated the front part will be redone with a new flange(the factory one broke), new adapter, and the used front section will be replaced to clean it up a little. i don't like how the front section looks like a hack job but once i get my headers and ORY it will be cleaned up alot better
  8. #58
    Flowmaster sells a y piece u can use to go from ur ory to 4" & no reducers turned backwards...
  9. #59
    So its been a while, but I went with 2 magnaflow 14419's and here is how she sounds under load outside the cab
    2oo6 25ooHD 6.oL,
    Current:
    Airaid MIT
    AFE Dry Flow Filter
    Twin Magnaflow 14419's
    Next part is up for debate
