Page 6 of 9 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 51 to 60 of 89
Thread: Feeler: 1994 ext cab 1500 w/ 2002 5.3/4l60E installed - Central Florida
    Nov 2009
    Fort Smith, Arkansas
    Ya well I'm sure we can work somethin out. I'm excited bout it so lmk when we can meet if we decide to do so after I check out the pics.
    Jun 2009
    Cocoa, FL
    I went out and took a video with my phone, it is 5 megapixels, but idk how it turned out. Im working on uploading it now.
    I found my video camera and charger, so if the phone doesnt work, I will use that.
    I also took a 2nd video of it idling, then rev up, then it coming down and dying (when releasing the throttle).
    Jun 2009
    Cocoa, FL
    Ok, so I got the videos uploaded. The sound is a little jacked up when the phone is too close to the manifold, but I think it will do. If you wish, I can charge and use my video camera, which worked fine at the drag strip, no distortion on the sound. Instead of taking pictures I just did a walk-around with the video, but if you want still shots, I can do that too.
    Nov 2009
    Wow you werent a kiddin bout havin a buttload of stuff on the inside and bed of the truck lol. Some of the underhood and undercarraige shots were a little distorted probably from the mix of bright sunlight and dark areas. If you could grab some better shots of those with either your vid cam or a better still shot cam that would be awesome.
    Was the y-pipe installed in that vid? It looked like it was open manifold or somethin but I couldnt tell.
    Do you plan on doing anything to it before I get it?
    Fixin the fuel tank strap?
    Is there a reason why the front grill, etc. are off?
    Do you have the matching wheel and tire for the front drivers side?
    Good luck at the track!
    Jun 2009
    Cocoa, FL
    y pipe not installed, need to weld in the cat replacement pipes, will do that before delivery. the manifold side of the y-pipe is bolted to the manifolds for o2 sensors, I just need to weld in 2x 12" pieces of pipe in place of the cats.
    front grill removed to install aux factory trans cooler, PS cooler
    I do have the matching wheel, tire had a leak.
    I will take care of stuff as I have time. I will see about getting the fuel gauge to work again (like I said, I think it is a ground), and I will attempt to fix the strap. If not, I will have a replacement to go with the truck.
    i will get true pics and a true video when i get home tonight.
    Jun 2009
    Cocoa, FL
    here is the link to the new pictures and the new videos. the ecu seems to be learning, as it didnt die this time after revving.
    http://s34.photobucket.com/albums/d1...20and%20video/
    Jun 2009
    Cocoa, FL
    photobucket isnt wanting to upload my new 135mb video, so i am uploading it to youtube
    HERE is the youtube link
    the audio still broke up a little bit, but not horrible
    Nov 2009
    looks good. that vid is MUCH better. Thnks
    Jun 2009
    Cocoa, FL
    oh, i forgot, pay no attention to the wires underneath the driver's dash, those are for the tach and water temp gauge up on the dash lol, those arent dash wires
    Jun 2009
    Cocoa, FL
    GRRRR, i hate technology. I took way more than 18 pictures, but for some reason they didnt get transferred to my computer. I will get them put up now
