Page 6 of 11 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 51 to 60 of 138
Thread: How to 4L60E to 4L80E trans swap
    Yeah, after rebuilding my 60e five times I had enough. Anyone need a 60e with some really good parts in it and a busted forward sprag?
    San Marcos Texas
    And one 80E! LOL!
    So true, that 100k+ unit wore out. Now I have a fresh one that has been taking a beating so far. Theres nothing like breaking them in right.
    Jul 2007
    Tempe, AZ
    I did the 80e swap in my RCSB you will only need a shorter slip yoke to make the drive shaft work and you can get it online pm me if you need more info.
    A.J.
    RCSB GMC SIERRA 00
    TCI makes a controller but its not cheap. The diesels had a standalone 80e controller but you have to wire it up and I know its been done before. I'm not sure how you'd program it, though.
    Broken Bow, OK
    The Compushift is nice, but over $1000, that's right 3 zeros.
    Since he is running a TBI 350 couldn't he use a harness and ECM from a 93 3500 with the TBI 350 and 4L80e? Just a thought.
    As far as the diesel ECM, it would be from a 91-93 6.2 and 6.5 truck. Not sure about all the wiring involved. Apparently these ECMs can be kind of pricey too, since a lot of people realize what they can be used for.
    Sep 2010
    frisco, tx
    Quote Originally Posted by PitchBlackC3 View Post
    kinda speaking spanish to me as far as trannies go, but i gotta do something with this 700r4, and i really need the overdrive for work and hauling the race truck to the track and back, its a torque monster IMO, in other words, its a gu2 rear end(2.73, yeah, 2.73) and its walking 03-07 hemi pickups haha and
    4 bolt main TBI 350
    built 700R4
    casting#916 heads
    advanced timing to 12.5 degrees
    and that wraps it up for now!
    soon to come, high rise intake with nitrous plate, bigger cam, turbo 350 or 400 tranny with a floor shift, wet shot of nitrous(somewhere between 125 and 225) 10 or 12 bolt 373 with a locker, 20 inch chip foose torque thrust wheels, new paint probably metallic jet black, corbeau buck seats
    OK. I've been researching various diagrams of the PCM and transmission. If I use the blue side of the PCM and tie the #72 and 34 together and ground them, am I correct in thinking it will make the PCM read that the transmission is set to neutral (or was it park?). Either way, that is what I need...a "P" or "N".
    Thanks
    What size fitting did you use to convert the hard line to the AN fitting?
    Mar 2006
    Phoenix, AZ
    For those that are comfortable cutting and splicing wires or re-pinning a connector, you can do this method instead of spending the extra coin for a conversion harness. You'll still need the harness for the second VSS, but this takes care of the main round harness that plugs into the side.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
