Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 44 of 44
Thread: Newb from detroit first 6.0 build,need input
  1. #41
    ported and polished.
  2. #42
    Mar 2012
    Detrioit,MI
    Is there certain specs I should tell them to raise compression or the shop should know w. Tellin them my set up?.
  3. #43
    Mar 2012
    Detrioit,MI
    Finally got a chance to hit the track, went to Milan dragway in Michigan. I ran w. Some 18" drag radials at 24 psi and ran a 14.06 in 1/4 mile. Deff thought I would do better, have tune issue aswell as a traction issue. Should of tried running at a lower psi in the tires. 15psi cool?
  4. #44
    Arizona/Utah
    Quote Originally Posted by juanelo View Post
    Tire pressure is a game of try it and adjust down. 24lbs definitely sounds a little high, you would prolly see some better traction closer to 18or20. What is wrong with your tune? Trans side or a/f wise?
    What is your 60'?
