Page 5 of 17 FirstFirst ... 3 4 5 6 7 15 ... LastLast
Results 41 to 50 of 162
Thread: Time to get started 4.8 to 5.3
  1. #41
    Augusta, Ks
    I never take the plugs out. I always remove the whole switch.
    2004 Buell XB12s
  2. #42
    You can also use an electric heat gun to soften the resin sealing the two halves.
  3. #43
    Feb 2009
    Quality KY.
    You know what they say. Live and Learn. I hope I get to do more tomorrow. I hope to pull it before the weekend.
  4. #44
    Feb 2009
    Quality KY.
    Dose anyone have a part number or know were I can ge this bracket or know what year truck it came on.
  5. #45
    Quote Originally Posted by 3DTIM View Post
    Man no one said good luck at getting the plugs out of the neutral safety switch. Man never did get the top one out. Took the whole thing lose. Only got to work on it around two hours. Got the exhaust off most of the plugs apart. Man I happy to get started on it. The shifting part on the 4L80e will not work but should be able to use the 60 one. The Cable Bracket on the 60 will not work so I will need to find one of them it will take the one that goes on the pan bolts.
    i used one off a 60e and jon (dbrods) fabbed it up for me, its pretty easy if you got the tools he does i almost had it working with a hammer and mine is bolted into the pan bolts i also had to drill an extra hole so it would have the right spacing.
  6. #46
    Feb 2009
    Quality KY.
    Looks like that is what I am going to do. I have the tools. Need to Save a buck anyway.
  7. #47
    true that
  8. #48
    Be VERY careful of the connectors!!!!! Like Greg said, a lighter helps out big time. Please do me a favor and go back and double check your connectors and the wire's integrity at the connector. Don't ask how I know.
  9. #49
    Feb 2009
    Quality KY.
    Just a fast up date. Still waiting on the trans guy to get my trans done. Wiring is done new tune is here Motor is ready just need a trans. Will be 4 weeks Monday. Driving me nuts. If anyone want a good 4.8 and the 4L60e I will make them a good deal on them.
  10. #50
    Nice work! Let us know how everything runs once you get that new tranny in there. Running a higher stall?
