pulling heads and intake today.....and maybe the seats and airbag, just whatever i feel like doin.
just wanted to throw this out there, maybe look at getting some ARP head studs to go back on it instead of the stock head bolts, it will be some insurance for the nitrous and they arent to horribly expensive
Definitely a very good idea.Good call, Virgil.
where do i get these just any autoparts store.
Jegs, Summit, TSP, SDPARTS, search the internet. Be sure to get the right ones for your year model engine. LS1 style bolts will have four corner bolts in the rocker arm area at the ends that are shorter than the rest. Newer engines will have all 20 bolts the same length. I think that started in 2004, the 20 all being the same length.
the best studs would be 234-4317 if you have all 20 the same length. PN 234-4316 is for the LS1 with the shorter bolts as mentioned previously. Those are the stud kit PNs.
thanks guys![]()
If you want to go with bolts then 134-3610 is the 2004+ set that have them all the same length and 134-3609 is the older style with the shorter corner bolts. Be sure to pull your head bolts and confirm what you have before ordering.
