Page 4 of 51 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Results 31 to 40 of 504
Thread: Official NBS 4.3v6 to GEN 3 V8 swap Guide
  1. #31
    <div class='quotetop'>QUOTE(dlh2006 &#064; Nov 28 2006, 10&#58;30 PM) [snapback]74832[/snapback]</div>
    Fuel Lines: The stock fuel lines will not work with the new motor, you will need
    2 EAR-165056ERL -6 - 5/16 AN to tubing connectors Male end
    2 EAR-165006ERL -6 - 3/8 AN to tubing connectors Male end
    2 RUS-658490 1 ft sections of pre assembled 5/16 Steel braided hose with female ends
    does that ^ say that I need 2 of each of those parts listed? like 2 5/16 male end connectors, 2 3/8 male end connectors, and 2 1ft sections of the 5/16 steel braided hose?
    <div class='quotetop'>QUOTE(duckysbht &#064; Jun 23 2007, 03&#58;20 PM) [snapback]97570[/snapback]</div>
    that is correct&#33;
    http://i99.photobucket.com/albums/l2...hsigcopypt.jpg
    6.0 swap - TR224 112 lsa - 918 springs -7.4" comp pushrods- LS2 timing chain -Walbro 255LPH intank- Pacesetter LT&#39;s - Custom Y-pipe with Quickflow muffler - LS1 E-Fans - 160 stat - Nelson Tuned - Fuddle 3K stall - FLT4l65e w/ Vac MOD - DJM 4/6 - Doetsch Drop shocks
  3. #33
    <div class='quotetop'>QUOTE(dlh2006 &#064; Jun 23 2007, 03&#58;43 PM) [snapback]97572[/snapback]</div>
    haha thanks for the help. looks like we are talkin on two message boards
    Jun 2007
    maine
    what year was the truck you did this swap on?? i have a 1998 chevrolet c-1500 2wd 5 speed reg cab short bed with 4.3 vortec id love to have a gen III motor (5.3 liter) i have a 5.7 vortec im planning to put in but things can change
  5. #35
    I did a 92 and a 93. TRTTurbo did a 93. LS1Nica did an OBS 4.3 swap but I can&#39;t remember his year model. MOTOXLIFER also has an OBS Gen3 that I believe was a V6 in a previous life.
  6. #36
    I have a couple more questions about that steel braided hose and those connections. The 5/6 and 3/8 fittings slip onto the intake manifold, how exactly do they stay tightend on there? Isnt the fuel system under alot of pressure? And then as far as the fittings that go onto the fuel lines from the 4.3, once you cut them, will they stay on their as well?
    San Marcos Texas
    There is a lock built onto the line. It just presses on but you need a tool to remove it.
  8. #38
    Oh ok I see how it works
    Summary of my 4.3 to 5.3 swap
    Here is some of the questions I had way before the installation of the 5.3
    http://www.ls1truck.com/forums/v8-co...5-my-swap.html
    Here is the thread I created with pictures to go along with the process of swapping the 4.3 out.
    http://www.ls1truck.com/forums/pics-...cont-pics.html
    First of all, this is probably one of the easiest swaps from a v6 to v8, I thought. The only thing I wanna stress is that make you have EVERYTHING, you need. I mean everything. I expected this to take me no longer than 4-5 days, ended up being 3 weeks because I was under prepared as far as parts were concerned for this swap.
    Taking the 4.3 engine out is pretty simply. I got it out in a day. I didn't have to take off really any accessories other than the AC compressor, only because that doesnt work on the 5.3 at all. When removing the 4.3, make sure you plug up the transmission lines, and other various openings on the engine and body of the truck so that no dirt or debris gets in their.
    When installing the 5.3 make sure you buy/get both frame and engine mounts from another 1/2 ton.
    The big red battery cable as well as the negative cable from the 4.3 with not work. Or at least the piece of plastic that bolts to the bottom of the truck doesnt work. You can just take them apart individually and then use them, well thats what I did.
    Here are some part numbers, all of this is for a 5.3:
    Engine Temp Sensor - 10368798
    Dipstick Tube - 12563918
    Radiator Hose - 15792821
    Rear Oil Pan Bolts (2) - 12561387
    Ill add more when I come across it.
    - david
    Feb 2008
    I have a 98 sierra...will all this information apply to that truck if I was wanting to do a swap from a v6 to an ls1?? Also its a 5spd now and I want to go with the 60e trans...is there a parts list anywhere that shows whats needed for the trans swap??
